Timeline preview speed
yagakisan
Hi all,
I use DAZ mostly for simple loop animations but it's always a pain to check how it is going since the timeline play preview skips most of the frames and it's not possible to set any min/max speed.
It's not about the GPU or CPU power since if I can check the animation by playing it manually frame by frame (I mean by clicking on the "next frame" button), but I need it to be automatic and playing repeatedly the loop.
Please add this feature in the next version of Daz Studio!
I answer to myself because I feel dumb as I've just found an option I never used before: in the Timeline panel menù there is a simple option "Play all frames" that does exactly what I need.
Thank you!
double post
Hi thank you so much for sharing this minor detail, just had the same issue and it helped :)
