Workspace problem after new installation
vwranglervwrangler Posts: 4,991
I had to install Studio again on my Windows 7 workstation after a system reinstall. I was able to rescue everything in the appdata/DAZ 3D directories so that I didn't have to muck about with the database or anything, beyond copying from the rescue disk to the hard disk.
Normally I use Hollywood Blvd as my interface.
However, when I downloaded a new version of Studio 4.7 -- the regular public build, not the Iray beta -- every single workspace looks like it's been attacked by the City Lights workspace. I've tried uninstalling and reinstalling Studio, deleting the files in user layouts that it was ignoring anyway, and nothing helps. Everything is just dark brown brown brown. Which wouldn't be so bad if the menu items weren't black on dark brown, but they are and it is. I can't tell what anything is without mousing over.
I downloaded the installer from my account first. Then I redownloaded it. Then I downloaded and installed with DIM. Nothing helps.
Below is what Studio thinks Hollywood Blvd looks like now. Even the shapes of the tabs are wrong.
As far as I can tell, everything is working normally. It's just not at all what it's supposed to look like, and I would really really like it to go away.
Is there a way to just remove the City Lights workspace (one of which is listed as a beta, for some reason) and see if that makes Studio figure out what it's supposed to be doing?
Any help would be much appreciated.
    Nothing is wrong with the workspace/layout...it's just set to the Darkside style. Look under Style, in the Window dropdown and pick Style, instead of Workspace...switch to something other than Darkside.
  • vwranglervwrangler Posts: 4,991
    Ah, I see. Thank you so much! It had literally never done that before, so I had no idea what I was seeing or how to make it go away.
    I didn't think that it loaded to Darkside by default...but I use a modified version of it, so I spotted what it was, quickly.
