Simple rendering question
Assume default render setting.
Max time is set to 7200 secs (2 hours)
Yet.
Some renders are taking 3 to 4 hours.
What overrides time and how can I stop it
Yet.
Is 'use limits' checked under parameter settings?
Thank you.,,,,,,yes it is.
Sorry answered too quickly, can you point me to this setting, cannot find
Thank you
There's a lock, a heart and a cogwheel above the Max time setting (where you put in the 7200 seconds).
Click on the cogwheel and choose parameter settings.
Then check if 'use limits' is checked.
PS
Do you use a Render Queue?
In some cases the Max time setting doesn't work when using a Render Queue.
Bless you, would be embarasses to tell you how long I spent on this.
To be fair those settings are only visible whwn you hover with the mouse.
I thank you very, very much for this!!!!!!
Default settings, ,USE LIMITS
TIME SET 7200 SECS.
RENDERS STILL GOING OVER THREE HOURS
WHAT GOOD ARE THE SETTINGS WHEN THE RENDER DOES WHAT IT WANTS ANYWAY????
