how do I stop buttons moving when autofitting?
I just purchased Business Casual for G9 ( https://www.daz3d.com/business-casual-dforce-outfit-for-genesis-9 ) intending to autofit it to G8M. However, when I do, the buttons of both jacket and pants shift. How do I stop this happening?
Cheers, Lorraine
  • crosswindcrosswind Posts: 10,253
    Currently by auto-fitting, you have no way to prevent such an 'issue' from happening... you have to manually recreate the rigid follow nodes on the 'fitted' garment and bind those buttons.
    Use G9 instead
    Use G9 instead +1
  • felisfelis Posts: 6,504
    edited May 2023
    Technically I don't see a reason why rigid follower nodes is removed when autofitting.
    Autofit should change the rigging and the weightmaps.
    And you will have the same issue if you autofit  G8 items to G9.
    Post edited by felis on
  • MadaMada Posts: 2,065
    Its not possible to change the rigging and weightmaps because the buttons are not part of the original obj but is a prop or separate figure that's attached to a follower node on the clothing. Same reason that you can't autofit pants and a top at the same time if they're 2 different conformers.
    Rigid follow node information is saved in a wearable preset format, and not part of the original follower info so technically the autofit is not reading the attached props or follower nodes in the first place, its only reading the obj and textures.
    With autofit the obj is changed to fit the new figure position and shape, and the polygon that the node is attached to moves to a different position - the node has to be recreated in the new position, the button attached to it, and then saved in a wearable preset again.
    edited May 2023
    Many thanks @Mada ! Very comprehensive. BTW, I love your works ! yes
    Post edited by crosswind on
    Thank you :)
  • LorraineLorraine Posts: 1,057
    Well damn, so not what I was wanting to hear crying and recreating the nodes is well above my pay grade.
    Thank you, Mada, a very comprehensive answer though one I was hoping not to hear. This old dog has trouble learning new tricks.
    FSMCDesigns said:
    Use G9 instead
    not helpful
  • GordigGordig Posts: 10,803
    Interesting. I would have thought that rigid follow nodes were simply a set of transforms relative to a polygon or point on the target object.
    edited May 2023
    Oh, dear ~~ Just watch @mada's tutorial lah laugh: (03. Rigid follow node buttons)
