XI Dune Buggy
What is with the Original Size from the Dune Buggy. Render with Genesis 9 Original Size.
    LMAO! I guess if they had made a promo with a figure driving they would have discovered this, LOL You can always just scale it down.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    At a quick play applying inverse Poser scale works, so perhaps it was just a wrong choice in the ONJ importer. It should certainly be reported, however.
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,829
    bought this ages ago Hot Rod Truck https://www.daz3d.com/hot-rod-truck promo images look ok size wise but actual product at least for me
    1842 x 873 - 2M
    1898 x 901 - 2M
  • FirstBastionFirstBastion Posts: 8,074
    Anyone got a render of a Genesis8 character sitting in the driver's seat of  a properly resized duggy and posed to be actually driving?
    No full pose or render, but I did place a base Genesis 9 in my resized to inverse-Poser-scale version and the hands and feet seemed to place OK on the controls.
    Here is a quick one using the buggy at the initial size after the update presumably fixed the previous issue. I don't seem to have many driving poses in my library so I had to use one from a "hatchback" product - from that I did have to bend the legs to place on the pedals and straighten out the arms as she wasn't reaching the wheel otherwise when sat back against the seat.
    1600 x 900 - 1023K
  • melaniemelanie Posts: 807
    Yesterday, I got an update on it and it now works.
  • bombenleger58bombenleger58 Posts: 114
    Today i make the Update and it works correct!!
  • nabob21nabob21 Posts: 1,058
    The Xi Armored Patrol vehicle and Rapid Attack vehicle are also oversized.
    Richard, how did you apply the 'inverse Poser scale" to correctly re-size the dune buggy?
    And strangely enough, after I loaded the dune buggy, which seemed to be the correct size, I loaded  a couple of Dzfire vehicles and they are too big now too.
    You can get the scale factor from the OBJ export dialogue, then type 100*that number in the scale box for the prop - though I think I was mis-remembering, so it  wasn't Poser scale import and was pure chance that it worked.
