Adding to Cart…
today's version will have materials animation ex: ambient strength
and i'll include the assignment list for the mcjWurzkeils keyboards
Hi Casual
Thank you for the link much appreciated
I've now got the Sax Mechanism to open OK and the keys to press
This one is quite difficult, but its looking possible
I like the sound of the Ballad Tenor Sax
Looking forward to using your new version
Thank you for all of your hard work
another delay ... so ... tomorrow
( because i found out while
testing instances as midi targets
that mcjJet2 for DS4.7 needed a fix :
movie with an opening box office record rivaling Age of Ultron https://youtu.be/bXFBpqF3ylk
Hi Casual
No rush it's ready when it's ready and your Happy
I've noticed something that might be relevent
it looked like MIDIload became unresponsive
I added a target node key 1 from the sax
Selected a channel
Selected key 70,70
just used the default limits
on the timeline-keymate there it was np
no problem at all when you use a different target as each gets its own set of parameters
Starting again this time I used note 70,70 added it to the list, came up on timeline np
Then added additional note 69,69 added that to list ,came up on timeline in a different location
Then added additional note 68,68 added that to list, this time nothing seem to change on time line, hence me saying it looks like its stopped working
Does that make sense?
I assume it would be OK for different Target morphs on the same note, This is when I noticed "Scale" isn't available in Keymate
I assume the note range is a better way for say the Sax Octave button
Maybe it would be better not to allow multiple notes on the same target node or maybe it's possible to generate a new sub object
i think there were issues related to cases where more than 1 note targets the same property
in previous posts about the zebra head i mentioned the "OR" feature which i was supposed (did i or didnt i? i forget! ) to add
i'll do some tests using the Bach sax piece,
but i'll use the fingering for a flute! that should simplify the work
fig 1 using Audacity to make sure all notes are "loaded"
fig 2 the first assignment list saved as a text file
as long as you keep each column separated with a TAB, it could be "manually" edited using wordpad/excel
the other requirement is that you use very very precisely the correct words case sensitivity included
fig 3 - first success at loading a saved assignment list
fig 4 part of the issues to solve before i post the new version is
cases where you load an assignment list which targets objects
not currently selected or targets objects which are simply not in the scene (anymore )
also i want materials animation in that version
and wurzkeil support, key movements and key highlighting
fig 5 - selecting a parent node also makes the child node part of the prime targets list
...practical for instruments like the wurzkeil keyboards
Hi Casual
Thank you
Were all very excited about this, thank you for all your hard work and continuing effort
Kindest regards
Keiron
Hi Casual
i't looking great very well done
I've been learning how the mechanism of Sax works, so i'm looking forward to being able to animate it soon. Im still a litte stuck on what keys do what
The vast majority seem to have 1 key per 1 opening, but there seems to be some linkage between some keys that i need to understand further
Best wishes
Keiron
some progress here
also there will be the special mode to accommodate objects animated by more than one midi note
unfortunately with DS4.7 the material properties animations dont get saved in the .duf scene file
so you will have to use the animated materials exporter script i wrote for mcjJet2
example, the assignment list for the 88-keys wurzkeil prop
the keys are all parented to a node named "notes"
so you simply will select that node and start mcjMidiLoad
then select the source channel from the midi file's list of channels
and apply
so ... i have to make it possible to assign from a channel other than channel01 even if the assignment list says it's for channel 01
the first key on the left of the 88 keys keyboards is A0 which corresponds to midi note 9
i actually built this assignment list in Excel
copy-pasted it in wordpad as "plain text"
and saved it as a plain text txt file named wurzkeil88XRot7
since the animation movement is a 7 degrees x-Rotation of the key
the result of using this ''assignment list'' shows that i didnt destroy the program !
https://drive.google.com/file/d/0B74NpQ_FHc6cM1BpVG14VTVBSG8/view?usp=sharing
next time i'll see about materials animation, which requires special care because of changes between D|Studio 1,2,3,4
figure 1 : setting the stage for color-property animation
Hi Casual
Thank you I'm really looking forward to this version
Have a great week
Kind wishes
Keiron
Hi
"Welcome the Band"
Many thanks to Casual for the new 88 key Wurkzweil Keyboard very cool along with the very cool Guitar
working on mcjMidiLoad this evening
here you can see the order of the assignment list is now preserved upon load/save
i'll also add something to change the source midi-channel for the whole assignment list
for cases where more than one midi note influences a target property
there will be a "Layered Mode" which is more "expensive" in the number of keyframes it sets, i.e. 1 keyframe per frame
so the first time the script sees aNote event being applied to a target property
it will fill the timeline with the Min value for this Assignment item ( usually the value 0 )
then for each NoteOn event, it will fill the target property's timeline frame by frame with the ( Max * velocity ) value
it fills all frames between the NoteOn event and the NoteOff event
so the next time a midi note influences this target property, it will overlay its own NoteOn/NoteOff keyframes
when the "Layered Mode" is not in use, the script only keyframes the NoteOn and NoteOff frames
it uses "constant: interpolation. It's economical, but the keyframes are more fragile.
So if you intend to tweak the keyframes later on, it' will be better to use the "layered mode" and its solid keyframes
the last substantial change for the upcoming version
the 'Effect' column
for now there's only 1 possible Effect, it's called the Expand effect
any midi note velocity above 0 will be considered 100% velocity
no more half-pressed piano keys
eventually there will be more complex effects
yay a first test of the "Layered" mode, all the up-to128 notes of the flute track influencing one object's Y-Scale
click here for the google video - with audio! here
( tho this doesn't test the chords issue i think )
name that tune and win nothing
or win the new free mcjGibGit with pick guard mcjGibGitB
Hi Casual
Totally brill
looking great
Very well done
Keiron
new test, animating the ZTranslate properties of a 90 photo-panels figure ( see mcjBillboards )
each photo-panel is assigned to a note
when the note plays, the panel moves front-stage, else it stays back-stage
https://www.youtube.com/edit?video_id=CrFQ7bIxI5E
FIG 2 - the actual test i want to perform to test the "layered" mode
where more than 1 note influences the animation of something
( for example, on a sax when 2 notes require the same lever/lid to be pressed/closed
Fig 3 - The results are in and it's a success, the layered mode works as expected
( and without the layered mode the results were all wrong, of course! )
and audio-visually speaking the layered mode is the blue tube
https://drive.google.com/file/d/0B74NpQ_FHc6cWWVWZk1TVjNsdjg/view?usp=sharing
Hi Casual
Fantastic, excellent results the layering looks much better, great job that was a real pain solved, your very talented
Great job with the Save and Load for the Instrument configurations, much better
I'm looking forward to the piano keys moving down fully, not dependant on Velocity
Velocity usually controls the speed of the note playing and the samples - sound resulting loudness
were'as Breath Control would control loadness-tone and veleocity would control key speed on say a Sax or a Flute
Love the panels moving to the beat, nice touch
The Channel number change is also a very usefull addition thank you
If your feeling in the mood, the addition of a transpose would also be helpfull
I made a 61 key piano and an 88 key piano configuration and realised it needed to transpose the notes. I did this quite easily editing the config in notepad. I started note from 96 to 96 for note 87 instead of 84 to 84 for note 87 working down to note 0, I did get a small error from the BETA script as I entered 0-9 but is was OK when I made them 00-09
Feel free to send me a link, if you would like some Beta testing
fig 1 reshuffling the UI, using tabs
fig 2 - color animation support
Hi
Please find below two keyboards playing
https://www.youtube.com/watch?v=7mibIkUuVrs&feature=youtu.be
yay ! first test ( well i did it previously but using laboratory scripts )
of color animations and the layered mode
the cone's color is governed by any and all (3) notes being played (layered)
the Cube is linked to one note and the Sphere to the other
note 127 cant be heard, but it was used to make sure the midi file's first note was at t=0
( else the midi-to-wav converter Timidity would produce a time shifted wav file )
https://drive.google.com/file/d/0B74NpQ_FHc6ceWw5YjNVNFlrbkk/view?usp=sharing
same test sequence as yesterday
Fig 2. results, notice 1 keyframe per frame, but maybe this could be simplified ... someday
Fig 3 illustrates why, we will always use the one-keyframe-per-frame mode when working with Color properties
the Colors in DS are stored as 3 color channels packed into 1 integer, so they produce bizarre interpolations
and i can't seem to force the use of "constant" interpolation
I'm on the lookout for a fully rigged concert grand piano (think Steinway Model D or something similarly sized) that will work with this script. If anyone knows of such a model, I'd love to know about it. Thanks!
Hi Casual
Totally Brill, love the colour changing, LOL loads of fun
"the Colors in DS are stored as 3 color channels packed into 1 integer"
Are you saying that they are stored as RGB 0.0.0 to 255.255.255 like an IP address or 0 to 16581375
Hi augustchamplin
You might find something here but they look expensive
http://piano.turbosquid.com/3d-Models/3ds/max/xsi/c4d/obj
or
http://tf3dm.com/3d-model/piano-8271.html
or
http://piano.cgtrader.com/
or
http://www.contentparadise.com/productDetails.aspx?id=3324
if you find a static model of a steinway
it's almost sure you can make the keys invisible
using the material opacity in Daz Studio's surfaces tab
then you could very very easily extract the 88 keys from my free synth-clavier ( unparent the "notes" group )
delete the rest ( delete key )
and position/resize them to fit in the steinway
if there's more than 88 keys, it's also possible to extract keys 1 by 1 from a second clavier, but you'll need to rename (re-label actually) them
mcjWurzkeil ...
https://sites.google.com/site/mcasualsdazscripts5/mcjwurzkeil
Thanks, Keiron, I'll check out those links. Best wishes! --AC
mcjWurzkeil ...
Thanks, I'll definitely try the strategy you recommend! Appreciated! --AC
It is with renewed confidence in the success of the mission
that i embark on an evening of trying to roll-out a less-beta version of mcjMidiLoad :)
the 2 main issues are
- completing the materials-animation functions
- doing tests in DS4.7 ( there's important differences with DS1,2,3 for figure materials and morphs )
( in case you want to give Victoria's the Rudolph the red nosed reindeer effect , but in sync with music )
Fig3 - The mcjMidiVU instruments gets fast track treatment
Fig 4, since some objects, figures for example, have many surfaces/materials
the surface property selection will make use of a third drop-down-list
not shown here the Color channels
I wont include Texture-file animation in this release at least
though you can do texture animation using nerdy UV-Tiling modulation
