@Hypertaf: Zero pose for Humo?
lou_harper
in The Commons
Would it be hard to do an update or next pose pack with a zero pose added? I'm finding out that if you ad a pose then later decide to change it, the first pose doesn't full erease.
Have you tried zeroing the pose. Select the hippo, go to parameters, up near the top you see the lines with an arrow on it, in there go to zero and then zero figure pose. That should do the trick.
Thanks, that worked! You learn something every day.
Faeryl Womyn beat me to it.
If you're applying them from the sliders in the posing tab, just make sure you're not stacking them on top of each other. If you're loading them from the product content folder, each of them zero all of my other poses before applying, but this won't work for other product poses, so zeroing the pose manually is needed in this case.
Got it figured out, thanks!
I usually apply a pose from smart content, then manually tweak it.
