Extreme Closeup Makeup -- Eyeliner Issue
cafedeliccafedelic Posts: 10
edited May 2015 in The Commons
Been testing out Forbidden Whisper's "Extreme Closeup: Makeup" with G2F. Everything was going along swimmingly until I applied eyeliner. Then G2F's face went white... not just pale but total 255 white...
Messing around with the Face Surface Sliders didn't bring it back. Attached is a screen shot of DS 4.7 as well as how G2F looks in a render.
Help!
Post edited by cafedelic on
  • Ashfire45Ashfire45 Posts: 126
    Having this exact same problem!!! If anyone could reply and fix this, it'd be great! Especially as I bought it mainly for the eye liner.. >.>
    edited May 2015
    hmmm that usually suggests something like the product using a shader that isn't installed - I had the exact same with a character that used the Ubersurface 2, which I didn't own.
    I have this, but haven't tried it out yet.
    edit: yep, confirmed. All the eyeliners do it. Looked through the file and the settings, but scratching my head over why it happens - can't figure it out.
    Post edited by jakiblue on
    Found a way around it, although I'm sure anyone else could figure this out!
    Go into the LIE editor, add layer on top of your face texture, find the ForbiddenWhispers makeup folder, pick whatever eyeliner you want and there you go!
    Well I didn't figure it out :D :D I can't even figure out how to GET to the LIE editor..... *scratches head in confusion*
  • Richard HaseltineRichard Haseltine Posts: 108,425
    Since this is affecting at least two of you please report it to support.
    Sent to support.
    the bug tracker isn't around anymore, is it? The one where we used to log in and report problems with content?
    I sent a request into support - technical - and it's been passed onto bugtracker...which I thought wasn't around anymore?
  • fixmypcmikefixmypcmike Posts: 19,696
    Zendesk is the bug tracker now.
    Just received a reply from support that the product has been updated and the update should be in DIM. :-)
