Is there a way a way to set objects to memory..?
UpiriumUpirium Posts: 722
Okay this is going to sound weird but I have two major positions for my light helper which is for standard standing renders, and lower to the ground renders.
I have all of the parameter numbers written down on notepad and I copy and paste them when I need to but it's very annoying doing this all the time.
I move the light helper at the end, before every render, because it's usually set up high and it's hard to see the figure's expressions and stuff.
So I was wondering if I could have it memorize a location that I could set it to.
I saw something like 'create new master parameter'
If I 'set a master parameter' will it create a dial that moves it where I need it to?
Then I could save that scene and have it already loaded like I want it...
    Just save it as a new light preset.
  • UpiriumUpirium Posts: 722
    But it's not a light preset...
    It's an object that lights attach to
  • DzFireDzFire Posts: 1,473
    Possibly an ERC?!?
    Like a null that helps you aim the light? Can you save it as a smart prop of the light?
    I don't know what you mean by this, but this is the product:
    http://www.renderosity.com/mod/bcs/i13-pro-lights-and-light-helpers/90109
    It is a sphere that you move and the lights are attached to it
    I don't know what you mean by smart object.
    I just want to be able to move it to one place instantly without having to copy and paste the paremeters I use everytime into the X Y Z dials
