dress issue on the legs
HLEET_3DHLEET_3D Posts: 172
Hello,
I'm trying this product : dforce floral fiesta outfit for G8F
When I make the figure wear the dress, the leg goes thru the dress.
I tried to apply geometry (Smooth modifier) and change the collision item to the figure for the dress. The result is not great (see screenshot).
It's not the first time that I encounter this behaviour which make long dresses unusable.
Maybe I'm missing something !? As promo images show that the dforce dress should work (!)
Please help
Post edited by HLEET_3D on
  • HLEET_3DHLEET_3D Posts: 172
    I think I found a solution.
    I have to use animated simulation instead of "current frame". And make it start with the T pose (Start Bones from Memorized Pose to ON)
  • crosswindcrosswind Posts: 9,731
    edited May 2023
    Because the author did not make JCMs of thighs bending on this dress (pretty common for such a long dress with dForce)... You can first try Start Bones from Memorized... only, without a timeline. In most cases the result will be fine. If it's not, then use a timeline...
    Post edited by crosswind on
