Is there management tool for moving in and out characters?
Is there management tool for moving in and out characters from library to certain directory, including the data and runtime?
So it wont bloated daz
  • crosswindcrosswind Posts: 10,276
    edited May 2023
    There's a Content Gatherer: https://www.daz3d.com/content-gatherer which may be helpful.
    Post edited by crosswind on
  • Richard HaseltineRichard Haseltine Posts: 111,444
    You can also install to different location by setting the path in Install manager or inside Daz Studio, then use different content directory sets to add or remove the locations.
    This is what I do. I use DIM. So if I want to move anything to a different directory, I use DIM, select each product I want to move, uninstall it, re-install to the new directory, which I create directly in DIM.
    If you keep the zips anyway you can just select the items in the Installed tab after setting the new paths, right-click, and choose the option to Reisntall Using current Paths.
