Material for figure origin?
I have a figure I created a while back. I applied another figure's base material to the new figure. They are both G8.
Now I need to figure out which figure that skin material came from originally, because I want to apply that same material to another figure too.
Is there any way to find out which figure's skin material was used?
I looked through the Surfaces pane on the new figure, but could not find the info.
Please help.
Post edited by vonHobo on
Select a surface, say 'Arms', in the Surfaces tab, hover the mouse over the the Base Color image thumbnail and it'll show a larger thumbnail and underneath some metadata including the path to the file. This path usually includes the creator's name and character's name (assuming the creator set things up like that). That should give you some clue.
If you just want to load the skin material onto another character then just save the material from the donor character as a Material(s) Preset.
Worked like a charm! Thank you!
