why are all these ds slider labels dark?
MistaraMistara Posts: 38,675
edited May 2015 in The Commons
how do i make them white so i can read the things?
thanks.
Post edited by Mistara on
    edited May 2015
    how do duplicate an object?
    i've selected the light. want to dup it and slide it over to the next fixture.
    did copy.
    but now how do i paste it?
    ctrl+v doesn't paste another light.
    thanks!
    1757 x 957 - 327K
    966 x 676 - 138K
    1085 x 825 - 190K
  • Richard HaseltineRichard Haseltine Posts: 109,287
    edited May 2015
    Edit>Duplicate>Duplicate Node(s)
    Or Create>New Light of whatever type, then click More Options and check copy selected item.
    Copy/Paste is for settings, not items.
    i don't have 'duplicate or duplicate nodes on my edit menu ????
    1757 x 957 - 327K
  • nightwolf1982nightwolf1982 Posts: 1,239
    Darkened Sliders usually indicate hidden parameters, clicking the gear icon and choosing Hidden > Unhide will make the label visible.
    Duplicate was added to 4.7 and up, need to update Daz Studio.
    edited May 2015
    why hide simon's expressions? makes no sense.
    unhide didn't work.
    spend hours fiddling things to be able to read it, light it, walls and things load all over the place, un-shmootz-ify shadows
    and then i don't know how to save it.
    oscar mike gulf i'm never gonna finish my book foofs weep-weep-cry-throwinthetowel
    You appear to be using DS4.6 The Duplicate option is new to DS4.7
  • alexhcowleyalexhcowley Posts: 2,406
    edited May 2015
    thanks.
    Change your style. On 4.7 and 4.8 there are three styles, the first of which is dark and very difficult to read if, like me, you are north of 50 and never had really good eyesight to begin with.
    If you are still on 4.6, the menu option may be different but it will still be there, somewhere.
    I'm doing a render at the moment so I can't give any details but try exploring the style options on the windows menu.
    Cheers,
    Alex.
    Post edited by alexhcowley on
  • StratDragonStratDragon Posts: 3,278
    edited May 2015
    thanks.
    in the "Darkside" skin go to
    Window>Style>Customize Colors
    change the Medium color (pretty sure, I don't have my PC in front of me, Im on my mac with defaults) and change it.
    the problem is in that skin the color of the hidden parameter names is also the "gray" color of all the palette backgrounds. If you change it you can wreak havoc with other elements of the interface. It should be separate.
    There are items, especially clothing that trigger morphs that cause poke though and without being able to show hidden you may not find them and when you do it's impossible to read the name or more importantly the value.
    The time consuming work around is to make each parameter individual visible (not hidden) in it's control panel.
    [edit] submitted as a feature request
    https://helpdaz.zendesk.com/requests/192031
    371 x 765 - 77K
    362 x 198 - 33K
    Post edited by StratDragon on
