Multiple versions of Daz Studio
anepher
Is it possible to have multiple versions of Daz Studio installed using the same content?
anepher
It's possible. I have 4.15 installed along with the 4.21 beta and have seen other users on the forums mention having multiple versions. Pretty sure DAZ frowns upon it thouigh. Also unless you have installers for older versions backed up, you are stuck with the latest since DAZ doesn't offer d/ls of older versions.
Daz officially supports having one version of the beta and one version of the general release installed, but not having multiple versions of the general release for example.
Besides, the configuration / layout files are stored in the same folder in appdata, GR and PB, so you have no way to separate them for different versions
With recent versions you could use the command line to give each a unique instance name, with its own settings.
@Richard, you meant this ? Or some other command line console?
Yes, that (although you don't haev to use that script to set the shortcut up, and you would need to edit the target to point to the correct DS version).
Right~ I'll try again since I usually just tick Start Process and Accept, then after the instance is closed, the folder in appdata is gone... I should've had more tests...
