How to disable Wire Bounding Box when Moving / Paning or Rotating a model.
The first image shows a normal view.
Second image shows how subject display when moving or paning.
Please help me to fix this. Thank you!
  • Richard HaseltineRichard Haseltine Posts: 109,378
    Open the Draw Settings pane (if it isn't already - Window>Panes(Tabs)) - and Manipulation Drawsrtyle to Use Current (Off) which means don't use a special mode when adjusting, just do what the Viewport is doing.
  • Obrigado! Estava procurando por essa solução também.
