Uber Environment question
deleted userdeleted user Posts: 1,204
In a lot of my renders. the Uber Environment main source of light seems to be coming from the ground. Yet my spot lights are from above.
Is there any way to move around where the source is coming from?
  • Richard HaseltineRichard Haseltine Posts: 109,347
    No, but you can use a map for the environment and that will control the light source direction. There are presets to apply several maps in the uberEnvironment folder, or you can load a map directly in the Parameters pane.
