Looking for
PopTart's GalleryPopTart's Gallery Posts: 74
edited May 2015 in Product Suggestions
I'm looking for the morph package or parameter that allows you to turn the bland looking Genesis Female into this beauty: (See pictures
Post edited by PopTart's Gallery on
  • PopTart's GalleryPopTart's Gallery Posts: 74
    I’m looking for the morph package or parameter that allows you to turn the bland looking Genesis Female into this beauty: (See pictures)
    563 x 1300 - 542K
    1000 x 1300 - 202K
  • scorpioscorpio Posts: 8,533
    This is probably a good starting point
    http://www.daz3d.com/aiko-6
    edited May 2015
    Its not Aiko, I think: http://www.daz3d.com/harpoon-girl-bundle
    edited May 2015
    The images you linked to look as if the Aiko 6 base morph is used (the long legs are a bit of a clue) then the face and body may be tweaked a bit.
    Post edited by scorpio on
    Well it would make sense since the new DAZ seems to be capable of taking clothing from one figures and conforming it to another.
    Are you wanting to alter Genesis or Genesis 2 Female - Aiko 6 is a morph character for Genesis 2 Female.
    That's pretty much what I'm looking for. As a college student, I'd rather not spend $44
  • Richard HaseltineRichard Haseltine Posts: 108,598
    Merged duplicate threads.
    um...K?
    You're not going to get Aiko 6 without buying her. Your only other option is to create a similar shape using whatever morphs you have available, or create your own morph.
  • IceEmpressIceEmpress Posts: 639
    There is no need to spend that much unless you really want it ASAP. Daz occasionally has sales for their original figures. That's always when I buy mine. In fact there are few instances when I don't buy something that isn't either a PA item or 45%+ off. At 50% off, A6 base costs 22 bucks. However, the starter bundle is on sale more frequently than the base, and usually requires you purchase a certain product with it. A6 starter is 90 bucks, but if you're willing to wait, the base is always available sooner or later. I snatched it up like-- last December I think, but there have been more opportunities since then if someone wanted her-- that said, I don't know how cheap those opportunities would have been once you factored the required "today's march madness or still mad" product into the equation, esp. without a PA club membership, which if someone played their cards right, might have given them 66% off A6 base-- i.e. pay 15 bucks, and in some cases, 51% off for the required MM product, which would still have likely cost 8~13 bucks *thus 28 bucks total* unless you got a clothing texture set that you might never use (in which case the price would be more like 3-5 bucks-- however, often times you had to buy 2 or more first-- which means spending more like 31 to 41 bucks, which basically negates the sale unless you got the aforementioned clothing textures, or a PA any-program texture item which is typically 3 or 4 bucks, thus giving you a total of more like 26 bucks. Of course, if you were REALLY lucky, then the sale would merely require "any new relase", which, if you had a PC membership, might cost you as little as 21 bucks total, and probably give you two products that you'd actually use.)
    Now, taking advantage of these sales and getting the most frugal price takes time-- you may need an hour of free time, which a student might not have, and it would also require a 3 month or more PA membership (24 bucks, and if you can't spend an extra 28 that month, then you'd better hope that the sale you're looking for doesn't happen that month.)
