AN Girlfriendz scale
marble
I bought several Aave Nainen products in Fastgrab, etc. in the past week. Today I got around to trying the Girlfriendz bundle and, to my disappointment, found that the clothing doesn't scale.
Or rather, it does until any of the included poses are applied. Then it reverts to full size (whether that be G2F or Josie). For me, this is a big problem because I hardly ever use out-of-the-box characters. I like to have bigger, smaller, older and younger. I have the Zev0 ageing morphs and Growing Up bundles and these clothes are not suitable for any of them.
Unless I'm missing a trick?
The odd thing is that I've just tried the Ordinarily Two dress with a G2F pose on a scaled down Zev0 body shape and that scales perfectly, so is this just a thing with the TShirt product?
Just tried with the Merimay dress too - that one scales well too. So it seems to be a thing with the TShirt only.
The base shape scales as it should, where you will run into issues is the draped morphs that match the poses. These morphs were created on the adult female shape and provide different "size" options (medium and large) so when you apply them to a child's shape the breast area remains "adult". This set was created long before Zev0's Youth product was available so there aren't any morphs in the product to support it. Because of the unique medium and large fit morphs on the T-Shirt it does work a little differently than my other sets. All of the other clothing items in the GirlfriendZ set work just fine on the Youth shape and for the most part auto follow works well on the T-Shirt base shape. You could use the DFormer to reshape the breast area after applying the morph or export the morphed shape for adjusting in another modeling software then load back in as a new custom morph.
I'm not sure there would be enough demand for a set of Youth morphs to justify the time it would take to create them but I would consider doing that if there is enough interest.
Replied to your PM, Aave.
Thanks.
Hope I can attach screen shots here ...
And here's my settings ...
Here's another example - this time using the included TJ poses ...
Okay, it looks to me like you have applied both the Large morph under Adjustments tab and the Large pose matching morph. Here are some screenshots so you can see the difference. You cannot use both at the same time as they "stack" one morph on the other.
Firstly, thank you Aave for such a quick response on your weekend. Much appreciated.
Yes, we both realised what I was doing wrong at the same time and our PM's crossed stating the same thing. I hope this helps if anyone else gets confused by the same issue.
