How do I edit the mesh of some clothing?
I've googled this and all I come up with is how to delete polygons or change the materials. I need to move the polygons because adjusting the actor isnt going far enough. I see a plugin mesh graber but isnt there a way to move polys in DAZ?
as you can see in mixamo im having the leg around the crouch area poking through.
  • felisfelis Posts: 5,931
    In Daz Studio you can move mesh with d-former, push modifer or mesh grabber.
  • Ok perfect thanks for the info the push modifer looks like it will do the trick.
