DAZStudio => GoZ question
MasterstrokeMasterstroke Posts: 2,334
If you have a Character in your scene, complete with geocrafted props, conforming hair and clothes, how to select, what single figure of those is loaded into zBrush via the GoZ plugin?
I'ver neither found an option to select in DS, nor in zBrush.
  • Richard HaseltineRichard Haseltine Posts: 108,758
    Items should be sent across as subtools, so you can always delete the unwanted ones in ZBrush and just work on the figure. Only the selected sub-tool is sent back to DS, as I recall.
  • MasterstrokeMasterstroke Posts: 2,334
    AHHHHH Subtools, that's it. I'm new to zbrush, that's why.
    I just didn't know, if this selection has to be made in DS on export or in zbrush on import.
    And now that, I've found out, how that subtool thingy works, doing morphs will be so much easier now. Thanks for help :)
