Genesis 2 Female morph bundle question
Hi, recently I purchased the Genesis 2 Female morph bundle. The purpose is because some character presets here and at rendorosity requires genesis 2 female morphs to go along with it. Now, I have Victoria 4.2 base and v4 morph ++ to inject(INJ) so I can use character presets that I purchased. But for Genesis morph bundle I don't see any Inject(INJ) or Inject Remove(INJ REM)
so how do I use or active the genesis 2 female morph head and body on genesis 2 females character?
Thank you
Once installed Genesis Morphs will auto load onto your character as its added to the scene, so there is no need to inject the morphs anymore with this Generation of figures. You can then select the figure and access the morphs via the Shaping Tab or under Parameters Actor Tab via sliders.
awesome, thanks for the info
There are some that are only visible in Parameters...
