lost my, My Stuff panel and it's not in the add panels
kodarrkodarr Posts: 32
I wanted to move the panels back to the left and clicked close panel on the My stuff panel. Now I'm looking to add it back on and can't find it. I closed and reopened Daz 3d and it's still gone. I can't add new models or clothing or anything because I have no access to the items in my library.
How do I get this panel back?
thanks for the responses as of now I can't do anything in the program.
  • fixmypcmikefixmypcmike Posts: 19,692
    Window > Tab, it's been called Smart Content rather than My Stuff since the very early versions of DS4, current version is 4.5.0.114
  • JaderailJaderail Posts: 0
    Second Tip: All your Items are in the Content Library Tab also. Just not Smart, you will need to find the item to use it. No automatic this item goes with that item thing.
  • kodarrkodarr Posts: 32
    Thank you both. I was just looking at the tutorial videos and saw it was called my stuff on there and couldn't find that pane anywhere in the program.
    Run DS and go to HELP do the ABOUT DAZ STUDIO. Tell us which version you are running. It sounds like your behind on updates.
  • Richard HaseltineRichard Haseltine Posts: 108,154
    No, My stuff was the old name - if the pane is called Smart Content then that doesn't mean it's an older version of DS, rather the reverse.
    I should not post that late, my brain took a nap and did not tell the rest of me.
