Face Transfer Morph to G8.1
so ime having trouble, with the rig on G8.1. when i use a G8M Face Transfer generated morph on a G8.1M model, the rig breaks.
nothing works as it should. For Example, when i turn G8.1 "Blink" Dial, the eye lids strech out, and pass through the eye balls.
the main problen im having is when i transfer theG8.1M Character to unreeal, using Daz to UE5, for live link mocap, the eyes move up in the head, and the lips deform real bad.
  • Richard HaseltineRichard Haseltine Posts: 109,357
    Genesis 8.1 does not, by default, have access to the Genesis 8 expressions - I think to avoid over-loading the figure when it has a different expression system. My suspicion would be that something that is meant to link to the Genesis 8 expressions is now firing up in the wrong way, and so producing undesirable results. It is possible to make the Genesis 8 expressions available to Genesis 8.1 by removing the dummy files that match them from the Data folder.
  • anonymousinfinteanonymousinfinte Posts: 9
    edited April 2023
    i tred something just now, "adjust rig to shape", and it working. !!!!!
    and thanks for the input, ill check it out
    Post edited by anonymousinfinte on
