Installing DAZ on secondary drive
Hello!
I'm looking to getting back into DAZ, after years of falling away from it. I want everything to be installed and run from my secondary drive, but I'm having problems with getting that working. See attached picutres, where in one of them you can see the error message I get when trying to initiate the content downloads from in DIM. Then in the other pictures you can see the path changes I made on the DIM settings. I'll really appreciate any help at all on getting everything running properly off of my secondary drive, as I don't want anything with the default paths because the default paths would put everything on my OS drive.
Thanks!
  • Richard HaseltineRichard Haseltine Posts: 109,534
    The operating system protects the Program Files folder - I would susect that is your issue, at least in part. Move everything but the software destination out of Program Files
    That solved it, thank you!
