The "Einstein Tile" A geometric shape that does not repeat itself when tiled
2»
  • ColinFrenchColinFrench Posts: 649
    Escher would have had fun with this tile.
  • LinwellyLinwelly Posts: 6,069
    That for sure surprise
  • LeatherGryphonLeatherGryphon Posts: 12,225
    edited April 2023
    Are we sure that its apparent repetition isn't really just momentary stuttering?indecision   And would a momentary stutter be sufficiently exact to establish a proper repeating tile?
    And, so far there has only been pictures of untextured tiles, the surface would look quite different if there was real textures rotating with the tile.
    edited April 2023
    But would be perfect if one was trying to tile a large plane with T-shirts(or stylized teapots).yes
  • Here's one I made in Illustrator and Photoshop Elements, just messing around with putting a pattern on the tiles.
    2748 x 1924 - 1M
  • stem_athomestem_athome Posts: 526
    Chumly said:
    The cool thing, for our purposes though, is that if each of those tiles was a Patch of Grass, or a section of cobblestone, it would look a lot better and natural than the normal tiling Daz uses now and which the eye can find the pattern pretty quickly.
    You can make tiling look more random by creating a procedural mix.
    Simple example.
    Pic1: Stone texture repeated 3 times.
    Pic2: Same texture repeated 3 times, but with a rotated layer, mixed using perlin procedural texture.
    It is a case of rotating/translating the top layer and scaling the weight (perlin noise) size to get a good result.
    800 x 800 - 726K
    800 x 800 - 731K
  • ArtiniArtini Posts: 10,567
    Sorry, but I still see the pattern repetition on that.
    edited April 2023
    Simple example.
    That second image (with perlin noise applied) is a good example and gives illusion of non repetitive patterns.
    Post edited by Artini on
    I like that laugh
  • FirePro9FirePro9 Posts: 456
    Another article about potential use of the Einstein Tile in material science.
    https://www.thebrighterside.news/post/einstein-shape-tiles-will-revolutionize-material-science
    Also, cool alternate image provided.
    1108 x 698 - 286K
    Here is a link to a Jan. 2024 article in Scientific American bringing us up to date on the latest discoveries in non-repeating tiles, and a summary of how the "Hat", the first "Einstein Tile", was found.  In short, there are more ein-stein tiles such as the "Turtle", and a family of tile shapes that do not require a tile to occassionally be flipped (reflection), they call "Spectres".
    https://www.scientificamerican.com/article/inside-mathematicians-search-for-the-mysterious-einstein-tile/
  • kyoto kidkyoto kid Posts: 42,114
    ...years ago (back in the 3DL days) I found an Einstein Tile texture. May still have it on backup media.
  • If you use apps which create seamless repeating patterns and do it from an image of Einstein Tiles, the Universe will explode (again).
  • Matt_CastleMatt_Castle Posts: 3,091
    Given that the Einstein tile wasn't even known to exist until last year (and some theorised it might not even be possible), I'm not sure how you could have a texture of it from many years ago.
    There's even relatively recent Youtube videos on the entire subject of these non-repeating tiles that eventually conclude "The smallest known sets are two, and we're still not sure if a single tile set can exist".
