sometimes you have to do things sideways
WendyLuvsCatzWendyLuvsCatz Posts: 40,573
edited February 2023 in Carrara Discussion
I have an interesting issue with some of my softwares (not Carrara, postwork ones)
1920x1080 is not the same as 1080x1920 in some because there is a maximum height they can cope with
after fighting countless errors the bleeding obvious occured to me
I need to render sideways!!!!
can rotate it afterwards
it was Flowframes interpolater in this case but encountered it before
the trouble is YouTube shorts are vertical shots and still usually HD just portrait
  • 3drendero3drendero Posts: 2,029
    There is also the modern option of rendering at much lower resolution and using a good AI upscaler. The free option Video2X also links to free Google cloud rendering, if you are busy with Carrara non-stop and cannot afford a second AI render: https://github.com/k4yt3x/video2x
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,573
    I use Waifu2X-Caffe
    rendering bigger is always better though
  • DiomedeDiomede Posts: 15,410
    Thanks for this heads up.  I often forget seemingly simple solutions.
    3drendero, thanks for the link.  I have never tried video2x.
  • bytescapesbytescapes Posts: 1,914
     "I've lived a life that's full
      I've traveled each and every highway
      But more -- much more than this -- I did it sideways."
  • SileneUKSileneUK Posts: 1,977
     bytescapes   laughlaughlaugh  Silene
