The "Einstein Tile" A geometric shape that does not repeat itself when tiled
FirePro9FirePro9 Posts: 456
edited March 2023 in The Commons
Apparently the elusive "Einstein Tile" has been discovered and it is a 13-sided polykite shape that when tiled never repeats itself. This would seem to be good news for us, eventually.
https://phys.org/news/2023-03-geometric-tiled.html
https://www.sciencenews.org/article/mathematicians-discovered-einstein-tile
Post edited by FirePro9 on
«1
  • algovincianalgovincian Posts: 2,670
    That's really cool! Thanks for posting.
    - Greg
  • HylasHylas Posts: 5,255
    huh cool
  • LeanaLeana Posts: 12,875
    Interesting smiley
    I wonder how the guy came up with that. It's actually quite a simple shape, which is the most surprising.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,396
    designed by obviously someone who has never had to clean the mouldy grout on the bathroom floor
  • ColinFrenchColinFrench Posts: 649
    Thanks for the links FirePro9, it's a fascinating discovery!
  • memcneil70memcneil70 Posts: 5,488
    That would make a great quilt!
    Thanks
  • LeatherGryphonLeatherGryphon Posts: 12,170
    edited March 2023
    Being a Roger Penrose fanboi, I knew about Penrose Tilescool, but this is even simpler.yes  I wonder if having a prime number of sides(13) has any bearing on the mathematics of why it works.indecision
  • FishtalesFishtales Posts: 6,218
    Is it just me or can nobody else see the pairs and triples in those images?
    edited March 2023
    not adjacent
    they shaded ones oriented the same way to illustrate that I think
    it may repeat a couple randomly but it doesn't continue in a pattern
  • TotteTotte Posts: 14,832
    Those are quite "repetitive" and they all look like t-shirts hanging to dry.....
    1774 x 1088 - 275K
    edited March 2023
    Repetition may seem to appear locally, but it's an illusion caused by our eye/brain's innate (but flawedraison d'etre, to try to find patterns.surprise   I'm sure that close examination of all the other tiles around/inside a "repeating" pattern would find differences.  If they've proved mathematically that it doesn't repeat, then it doesn't repeat.cheeky  Of course that also depends upon one's defintion of repetition.frown
    I think they're stylized teapots.indecision
  • FeralFeyFeralFey Posts: 3,948
    edited March 2023
    Very cool! Thanks for sharing. I love a bit of arty science. Now to scurry off and see how we can use this in 3D...
    edited to add: I realize that the einstein tile is a 2D construct, and therefore it's application in 3D would be limited to texture tiling - pretty much how it would work in the design industry with fabrics, flooring, wallpapers. But I think it's still a fascinating concept and I'm looking forward to see where this may lead.
    Post edited by FeralFey on
    yes
  • designed by obviously someone who has never had to clean the mouldy grout on the bathroom floor
    Use black grout. Then no-one, not even the householder, will see the mould. ;)
  • TaozTaoz Posts: 10,285
    Interesting question.  But the big question is I imagine, how to make the textures seamless.
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    The headlines on the articles are confusing if not misleading. It's not the shape that doesn't repeat, the point is that it is a single shape, it's that the pattern of how the shapes interlock doesn't repeat. This doesn't mean the same configuration exist either, it means that it won't occur at regular intervals as other patterns would. For example, you wouldn't be able to predict the same configurations repeating every X number of horizontal iterations of a pattern.
    Cool mathematic stuff being hidden behind poorly worded headlines.
    edited March 2023
    Um..., I think in this case, seamless is hopeless.devil
    Probably.  I'd rather think that fibonacci and other "natural" algorithms is the way to go - to imitate nature's seemingly chaotic randomness in a way that takes as little resources as possible.  Procedural shaders also work quite well in many cases, like these:
    https://www.daz3d.com/oso-shader-pack-1-for-iray
  • FirePro9FirePro9 Posts: 456
    For fun I modeled 3 objs of the Einstein Tile "Hat".  Per Wikipedia ( https://en.wikipedia.org/wiki/Einstein_problem ) the Hat is formed from 8 copies of a 60-90-120-90 kite, glued edge-to-edge and uses a mirror image as well (see attached image).
    1062 x 922 - 182K
    zip
    zip
    Einstein tile - Hat OBJs.zip
    6K
  • LinwellyLinwelly Posts: 6,067
    I would need a larger example to see if it's repetitive or not, for now I can see some repeating I marked one block of repe4at in green and the other in red, would need a larger one to see how the rest sorts in there but I have the impression it does sort
    1440 x 810 - 1M
  • Richard HaseltineRichard Haseltine Posts: 108,870
    edited March 2023
    There wil be local repeats, but if you draw a bugger box then eventurally you will reach a point at which the pattern does not repeat. Just as an irrational number may recur for a bit but will then stop recurring.
    I don't have the time or the engergy to follow up on the math of the article, that's why I thought it was a bit sad that there wasn't a larger sample which would visualise the thing. I can imagine it being like irrational numbers
    If you are interested, the first article links to the journal at the ends of the article which appears to be freely available at the moment, with more examples and explanations.
    I might take a plunge there, this weekend
    edited April 2023
    ok I found this article in German:
    https://www.spektrum.de/news/hobby-mathematiker-findet-lang-ersehnte-einstein-kachel/2124963
    which contains this graphic which adresses the repetitive aspect I noticed and shows why it's not repetitive in the end
    https://static.spektrum.de/fm/912/f2000/output2.png
    Also now I want a Penrose tiling for my DAZ rooms ... pretty please
    Post edited by Linwelly on
    Linwelly, that is an interesting article because it says that the lengths of the sides of the "Hat" can be varied, producing an infinite number of Einstein tiles.  They include an animated GIF of the Hat shape morphing between a 7-sided comma shape and a 6-sided chevron shape. The chevron shape seems so much simpler, not sure why they are fixated on the Hat shape.
    500 x 500 - 119K
    500 x 500 - 107K
    500 x 500 - 108K
    as I understood that gif both ends of the scale where the shape looses sides it as well looses it's function as einstein tile since they both clearly look repetitive
     Oh, that makes sense, thanks for the clarification.
  • The cool thing, for our purposes though, is that if each of those tiles was a Patch of Grass, or a section of cobblestone, it would look a lot better and natural than the normal tiling Daz uses now and which the eye can find the pattern pretty quickly.
  • ArtiniArtini Posts: 10,426
    edited April 2023
    How do we generate such tiles for Daz Studio, then?
    I also see how the pattern repeats, but maybe it is just related to the examples provided.
    In Unity there are some methods to avoid repetitive texturing on the terrains or the other objects
    and they work pretty well.
    Post edited by Artini on
