g3 anatomical elements
Hi all,
I require genitalia for the G3 male. In which store item might I find this?
Also, does it come with textures?
I'm not looking for the kind of 'enhanced' versions over at Renderotica, but a standard, human 'member' for antomical illustrative use.
Edit: Some morph packs on Rederotica point back to Michael 7 on the store here, including starter and pro bundles - can anyone confirm that genitclia is contained within both, or just the Pro version?
Adam :)
Post edited by kromekat on
G3 Male... You need to buy one of the G8 Male pro bundles that are not toon or teens.
For example; https://www.daz3d.com/michael-7-pro-bundle
Note the "What's Included and Features", for Michael it says "Genesis 3 Male Anatomical Elements" at the end of the list, meaning he comes with the 'tools'
Edit; The Anatomical Elements are included only in the Pro bundles for G3, G8.1 started having them also in other bundles (fits G8 also) and with G9, the geometry can be bought in "Genesis 9 Starter Essentials Expansion", https://www.daz3d.com/genesis-9-starter-essentials-expansion
Good day, to get the anatomical elements you need to purchase a pro bundle [ specifically an adult as I think it is excluded from the child bundles for obvious reasons ].. This si the same for each generation. Once you have the anatomical mesh (and the texture that comes with that bundle) you will find that many characters sold individually will also have textures for the same mesh.
Thanks for the info!
Is the G9 anatomy useable with G3 with some tweaks?
No, but if you have the G8 version and do the Scene Identification trick, they will probably work.
