Daz 4.8 Iray renderes still noisy and dots abound, screenshot provided with render details...
Hello,, here is a render i just did over night, i think it might have taken 4 hours or somethig, not sure, i was sleeping. The imae looks pretty good, but it doesnt seem to be as complete and unnoisy as it should be. Can anyone look at my progressive rendering setting an tell me what I should tweak to get a more complete render? I am using a laptop with intel hd graphics, 8gb of ram so yeah its a tiny computer but iray does work! Thanks!
    If you didn't change the default setting for the IRay render engine the rendering will stop at which ever of the following comes first, 2 hrs or 5000 iterations or 95% convergence. If you don't have a fast processor and/or Nvidia graphics card 2 hrs may not be long enough for convergence to reach an acceptable percentage level.
  • edited April 2015
    Would 5000 iterations be enough to "finish" a 2560x1800 size image if I set the time to like 10 hours?
    I was wondering about the convergence percentage, do I want to push tthat over to 100% in order to get an image with less dots? What about rendering quality? do I want to raise that any higher than 1?
    Post edited by smtelephone_cb7254b03a on
  • Richard HaseltineRichard Haseltine Posts: 108,465
    How is your scene lit? is it open or enclosed? What are your tone mapping settings? If there isn't enough light, or if the light can't reach the area you are rendering, then the render will take longer to converge. If the scene is dimly lit and you don't adjust the tone mapping to compensate then the render will take longer to converge. A simple looking portrait render shouldn't take that long, I don't think your issue is the time/quality settings but the lighting or the tone mapping.
    Looks an awful lot like a picture taken on a phone from about 6 or 7 years ago.
    That screams to me lighting/tone mapping as opposed to not enough time. I've found that overall, not enough time to converge issues have a different look to them. Like the noise tends to be concentrated in certain areas, or there are a lot bright fireflies or other things along those lines...it looks a lot like the what it does after the first few iterations...but a bit more refined.
    Not enough light/wrong exposure (tone mapping)...a more uniform noise/cheap camera photo look.
    And that isn't just an Iray observation...it is similar in any PBR render I've seen/done.
  • edited December 1969
    Thanks for the observations! Tone mapping it seems like a lot to take in, anyone have a good tutorial for a new user? Don't worry I'll Google it too lol
  • vex3dvex3d Posts: 130
    Just want to add that it is possible to adjust your tone mapping settings DURING render so you can see the effect without canceling/restarting.
    On your render progress window, if you look on the left edge, there's a tiny handle you can click to pop up the render settings. You can adjust the progressive/filtering/tone mapping from here.
    With that said, I still haven't found a magical tone mapping setting that works for all light sets and skin tones. Definitely something that needs adjusting per render unless you like the default look. ( who does?! )
  • ShawnBoothShawnBooth Posts: 465
    Can we get a screEn shot of this handle?
  • FishtalesFishtales Posts: 6,216
    Could you post a screen shot of Tone Mapping, Environment and the camera (if you have one setup) settings.
  • prixatprixat Posts: 1,617
    There are a couple in this thread:
    http://www.daz3d.com/forums/discussion/comment/837965/#Comment_837965 ;
    Thank you. Found it.
    Have a a render going, on 15 hours. I'm so happy with image, I'm willing to just let it go until it's finished. Then I tried adjusting ISO while rendering and it basically restarted the render?! Maybe I misunderstand the concept?
    15 hours, ouch!
    The restart issue is a recent development, some things have begun to trigger a restart, I'm not sure which.
