Reality 4 - Studio Edition and Lux Error.
eiliestl
Ok I have two mesh lights in my scene just like in this video .
https://www.youtube.com/watch?v=Xz-BuON0UEo
And when I load it up in Lux I get this error meg stating that there is no light source defined in scene ,nothing to render. And when I try to render it again and Daz crashes ..So what happened.....
Post edited by eiliestl on
Anyone????
I use Luxus as my bridge to Luxrender....and I've never encountered that error. Going to have to wait for someone much more familiar with Reality to comment.
Can you provide a screenshot of you scene in daz and a screenshot of Reality's light tab
are you using the light sets from the Reality props folder for R4 or some other set or method?
Just two Reality 4 mesh lights. Positioned just like in the video.
This work-a-rounnd works on most items that don't appear in Reality when they should do,
Select the 1st Meshlight and Press Delete, now goto the edit menu and select Undelete,
Now do the same with the other Meshlight.
Didn't work...
I am inclined to agree with PlatnumK, screen shots would be helpful to help you with your error...
if you haven't done so already post over at the Reality forums at runtimedna dot com or preta3d dot com as the developer of Reality doesn't check these forums but likely will there.
How do you have those lights set up in Reality. There are 2 ways to set up a mesh light in Reality 4 and they work slightly differently. The first is to convert the material of a mesh light into a light, which may or may not happen automatically when you load your mesh light. The second is to turn the material for that mesh into a light emitting material, for which they still may need a proper light for Reality to recognize.
