Need help on pores render, I never got any pore
functionfunction Posts: 285
I realized that I never ever got an iray render with pores, which means my work is not realistic, sad. I tried many figures, HD figures, SubD4, Skin detail resources, PBR Skin, add Base Bump map and Normal map, etc., as one example shown below, the Victoria 8 HD never shows her pores, like some advertisement pictures in the store.
What should I do? Please help.
Post edited by function on
  • Richard HaseltineRichard Haseltine Posts: 108,463
    That's very soft lighting, look at the faintness of the shadows. As a result fine detail really isn't going to show - if you want pores you need a sharper, more directional light.
  • functionfunction Posts: 285
    Finally got it.
    It needs a high value (I used 4) for Base Bump, and 1 for Normal Map, plus HD face map for the Base Color.
    The key for pores is high value Base Bump.
    838 x 821 - 961K
  • CASINCCASINC Posts: 76
    Like someone else said, darker or harder lighting. Try better lighting, different hdri's can create much different looks. Crank up the bump or normals past the standard 1 or 2. But really realism isn't about pure skin detail, it's the whole picture. Plus the overall skin texture itself is the most important, in my opion, a really good skin texture with the right surface settings doesn't need much pores for realism. Standard Daz models aren't actually very good, I'm kinda shocked they still have never adapted a better surface settings system. Plus plus, realism isn't just about a ton of detail, I mean go look at people's socially media accounts, these people do the anti-detail thing. They blur, light blur, apply filters and AI nonsense to remove detail and make everything look smooth, flawless, and "pretty."  I mean, I even apply smoothing modifiers to my characters. But again, the stock Daz skin setup isn't really that great. In the long run that's what will kill the realism the most.
