Genesis 8 Female -> Missing Files Genesis 3 Starter Essentials
lachilachi Posts: 102
Recently DAZ Studio started to show a missing files message about a missing file whenever I load G8F or G81F into the scene.
I did look in the log file but I could not figure out what's going on.
Could it be related to an asset which I installed recently?
Is it possible to identify the asset without uninstalling them one by one?
Edit: I uninstalled all recent assets and then installed them one by one until I found the culprit.
Apparently the Aging Morphs for Genesis 8 Female(s) are causing this but why?
There is no information on the product page and I could not find anything about it in the forums.
I have the Aging Morphs for males also and those don't have the same problem.
Post edited by lachi on
  • BejaymacBejaymac Posts: 1,960
    I'm going to assume "Bad Parent data" is the issue, but I need to see your log to confirm it.
  • lachilachi Posts: 102
     The log has hundreds of warnings and errors apparently and I cannot post it. It says "Body is 235531 characters too long" so I deleted most of it:
    2023-03-15 01:49:01.989 [INFO] :: Begin asset load (merge): /People/Genesis 8 Female/Genesis 8.1 Basic Female.duf2023-03-15 01:49:01.993 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00365 iterations after 8.219s.2023-03-15 01:49:02.022 [INFO] :: Determining missing assets...2023-03-15 01:49:02.141 [INFO] :: Setting textures...2023-03-15 01:49:02.185 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00374 iterations after 8.410s.2023-03-15 01:49:02.214 [INFO] :: Scanning for addons...2023-03-15 01:49:02.379 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00383 iterations after 8.605s.2023-03-15 01:49:02.580 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00393 iterations after 8.805s.2023-03-15 01:49:02.794 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00403 iterations after 9.019s.2023-03-15 01:49:02.996 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00413 iterations after 9.221s.2023-03-15 01:49:03.205 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00423 iterations after 9.430s.2023-03-15 01:49:03.414 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00433 iterations after 9.639s.2023-03-15 01:49:03.623 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00443 iterations after 9.849s.2023-03-15 01:49:03.830 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00453 iterations after 10.055s.2023-03-15 01:49:04.224 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00473 iterations after 10.449s.2023-03-15 01:49:04.993 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00513 iterations after 11.218s.2023-03-15 01:49:06.113 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00571 iterations after 12.339s.2023-03-15 01:49:07.347 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00635 iterations after 13.572s.2023-03-15 01:49:08.692 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00705 iterations after 14.917s.2023-03-15 01:49:10.009 [INFO] :: Creating node geometry...2023-03-15 01:49:10.014 [INFO] :: Creating UV sets...2023-03-15 01:49:10.015 [INFO] :: Creating materials...2023-03-15 01:49:10.146 [INFO] :: Resolving legacy figures...2023-03-15 01:49:10.146 [INFO] :: Preparing modifiers...2023-03-15 01:49:10.175 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00783 iterations after 16.401s.2023-03-15 01:49:10.226 [ERROR] :: Open File Failed - Could not read file: /data/DAZ 3D/Genesis 3/Female/Genesis3Female.dsf2023-03-15 01:49:10.226 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5962): Parent for modifier not found: CTRLMD_N_ZRotate_n20.2023-03-15 01:49:10.226 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1712): Modifier not prepared: CTRLMD_N_ZRotate_n20!2023-03-15 01:49:10.228 [ERROR] :: Open File Failed - Could not read file: /data/DAZ 3D/Genesis 3/Female/Genesis3Female.dsf2023-03-15 01:49:10.228 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5962): Parent for modifier not found: CTRLMD_N_ZRotate_20.2023-03-15 01:49:10.228 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1712): Modifier not prepared: CTRLMD_N_ZRotate_20!2023-03-15 01:49:10.230 [ERROR] :: Open File Failed - Could not read file: /data/DAZ 3D/Genesis 3/Female/Genesis3Female.dsf2023-03-15 01:49:10.230 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5962): Parent for modifier not found: CTRLMD_N_XRotate_n20.2023-03-15 01:49:10.230 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1712): Modifier not prepared: CTRLMD_N_XRotate_n20!2023-03-15 01:49:10.249 [INFO] :: Creating modifiers...2023-03-15 01:49:10.301 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1729): Modifier not created: CTRLMD_N_ZRotate_n20!2023-03-15 01:49:10.301 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1729): Modifier not created: CTRLMD_N_ZRotate_20!2023-03-15 01:49:10.313 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1729): Modifier not created: CTRLMD_N_XRotate_n20!2023-03-15 01:49:10.638 [INFO] :: Creating property aliases...2023-03-15 01:49:10.655 [INFO] :: Creating sum stage formulas...2023-03-15 01:49:11.189 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: abdomenLower:/data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Aging%20Morphs%208/abdomenLower_CTRLMD_N_XRotate_n20.dsf#CTRLMD_N_XRotate_n20?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Aging%20Morphs%208/BendfixAbdolowerbackSH2.dsf2023-03-15 01:49:11.189 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: abdomenLower:/data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Aging%20Morphs%208/abdomenLower_CTRLMD_N_XRotate_n20.dsf#CTRLMD_N_XRotate_n20?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Aging%20Morphs%208/BendfixAbdolowerbackSH1.dsf2023-03-15 01:49:11.751 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/Mousso/Jessamy/eJCMMSOJessamyMouthSmileOpen.dsf#eCTRLMouthSmileOpen?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/Mousso/Jessamy/eJCMMSOJessamyMouthSmileOpen.dsf2023-03-15 01:49:11.751 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/Mousso/Jessamy/eJCMMSOJessamyMouthSmile.dsf#eCTRLMouthSmile?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/Mousso/Jessamy/eJCMMSOJessamyMouthSmile.dsf2023-03-15 01:49:11.815 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20for%20Genesis%208%20Female%202.0.dsf#Ultimate%20Natural%20Bend%20Morphs%20for%20Genesis%208%20Female?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/UNBM%20G8F%20Lower%20Hip%20Definition.dsf2023-03-15 01:49:11.815 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20for%20Genesis%208%20Female%202.0.dsf#Ultimate%20Natural%20Bend%20Morphs%20for%20Genesis%208%20Female?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/UNBM%20G8F%20Foot%20Bend_R.dsf2023-03-15 01:49:11.816 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20for%20Genesis%208%20Female%202.0.dsf#Ultimate%20Natural%20Bend%20Morphs%20for%20Genesis%208%20Female?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/UNBM%20G8F%20Foot%20Bend_L.dsf2023-03-15 01:49:11.816 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20for%20Genesis%208%20Female%202.0.dsf#Ultimate%20Natural%20Bend%20Morphs%20for%20Genesis%208%20Female?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/UNBM%20G8F%20Collarbone%20Definition.dsf2023-03-15 01:49:11.827 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00869 iterations after 18.052s.2023-03-15 01:49:11.854 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6903): Formula output property not found: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLMouthSmileSimple.dsf#eCTRLMouthSmileSimple?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/Godin%20i3D/iG%20Sweet%20%26%20Sassy%20Expressions/iGSSE%20Sweet%20Smile.dsf...2023-03-15 01:49:12.327 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLAfraid_HD.dsf#eCTRLAfraid?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Aiko%208/eJCMAiko8Afraid.dsf2023-03-15 01:49:12.327 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6903): Formula output property not found: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eJCMAfraid_HD_div2.dsf#eJCMAfraid_HD_div2?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Aiko%208/eJCMAiko8Afraid.dsf2023-03-15 01:49:13.624 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00963 iterations after 19.850s.2023-03-15 01:49:15.072 [INFO] :: Creating multiply stage formulas...2023-03-15 01:49:15.079 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLEyesClosed.dsf#ECTRLEyesClosed?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Aging%20Morphs%208/MCM%20Eye%20Sag%20Top.dsf2023-03-15 01:49:15.081 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: abdomenLower:/data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Aging%20Morphs%208/abdomenLower_CTRLMD_N_XRotate_n20.dsf#CTRLMD_N_XRotate_n20?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Aging%20Morphs%208/BendfixAbdolowfrontUpbackSH2.dsf2023-03-15 01:49:15.081 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: abdomenLower:/data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Aging%20Morphs%208/abdomenLower_CTRLMD_N_XRotate_n20.dsf#CTRLMD_N_XRotate_n20?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Aging%20Morphs%208/BendfixAbdoLowbackUpfrontSH1.dsf2023-03-15 01:49:15.084 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20for%20Genesis%208%20Female%202.0.dsf#Ultimate%20Natural%20Bend%20Morphs%20for%20Genesis%208%20Female?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/pJCMkhCollarBnd45Tw-30L.dsf2023-03-15 01:49:15.084 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20G8F%20Collar%20Twist%20L.dsf#Ultimate%20G8F%20Collar%20Twist_L?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/pJCMkhCollarBnd45Tw-30L.dsf2023-03-15 01:49:15.085 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20for%20Genesis%208%20Female%202.0.dsf#Ultimate%20Natural%20Bend%20Morphs%20for%20Genesis%208%20Female?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/pJCMkhCollarBnd45L.dsf2023-03-15 01:49:15.085 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20G8F%20Collar%20Bend%20L.dsf#Ultimate%20G8F%20Collar%20Bend_L?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/pJCMkhCollarBnd45L.dsf2023-03-15 01:49:15.085 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20for%20Genesis%208%20Female%202.0.dsf#Ultimate%20Natural%20Bend%20Morphs%20for%20Genesis%208%20Female?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/pJCMkhCollarBnd-45Tw-30R.dsf2023-03-15 01:49:15.085 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20G8F%20Collar%20Twist%20R.dsf#Ultimate%20G8F%20Collar%20Twist_R?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/pJCMkhCollarBnd-45Tw-30R.dsf2023-03-15 01:49:15.085 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20for%20Genesis%208%20Female%202.0.dsf#Ultimate%20Natural%20Bend%20Morphs%20for%20Genesis%208%20Female?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/pJCMkhCollarBnd-45R.dsf2023-03-15 01:49:15.086 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20G8F%20Collar%20Bend%20R.dsf#Ultimate%20G8F%20Collar%20Bend_R?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/pJCMkhCollarBnd-45R.dsf2023-03-15 01:49:15.086 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6969): Formula target property not found: Genesis8Female:/data/Daz%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/Z3/UNBM%20for%20Genesis%208%20Female%202.0.dsf#Ultimate%20Natural%20Bend%20Morphs%20for%20Genesis%208%20Female?value - in file: /data/DAZ%203D/Genesis%208/Female/Morphs/K.H.%20Image%20Studio/UNBM%20for%20G8F%20and%20G8.1F%202.0/KHCollarboneDef.dsf2023-03-15 01:49:15.121 [INFO] :: Processing scene data...2023-03-15 01:49:15.121 [INFO] :: Finalizing modifiers...2023-03-15 01:49:15.121 [INFO] :: Finalizing channels...2023-03-15 01:49:15.121 [INFO] :: Finalizing materials...
    edited March 2023
    I quoted your post and was able to see enough to confirm it's bad parent data.
    Looks like Zev0 messed up with this product in the same way he messed up "Growing up" for G8F.
    Post edited by Bejaymac on
    Thanks for looking into it. Is this a problem or can I just ignore it?
    I also have Growing Up for Genesis 8 Female(s) but it did only show this message after installing the aging morphs.
    Maybe some of the errors also come from the growing up morphs, so I will uninstall both and look into the error log again.
    Finally I will install them individually to see which one is causing which problems.
    edited March 2023
    Growing up got fixed after I kicked up a stink on the forums about it, it still took a few months for it to get fixed though.
    In every Morph DSF file there is a line that tells DS what base figure that morph is meant for (the Parent), if it's the wrong figure then DS adds three error messages to the log and aborts the loading of that DSF file, now as this is a control asset it means that a number of other files are linked to it, and as that file hasn't been loaded it means the other files don't work correctly.
    I can see bad parent errors for three files, but can really only identify one of them (data/DAZ 3D/Genesis 8/Female/Morphs/Zev0/Aging Morphs 8/abdomenLower_CTRLMD_N_XRotate_n20.dsf).
    Best thing to do is report it.
    Thanks, I have seen all three errors now and I reported it to Zev
