Has anyone gotten eR Auto Breast Animator to do anything worthwhile?
I can see that it is creating tiny alterations, but not enough to be worth a paid product. I'm talking 1mm of movement on Firm, maybe 2 mm on Bouncy. I've got to frame by frame it to even notice, for about an hour I just thought it was completely broken.
Going into Custom isn't much help, just guess numbers and so far they don't seem to make much of a difference.
That isn't helped by the fact that whenever I hit Enter when entering a number, it resets all of the values.
Is anyone having any good luck with this? I'm about two seconds away from refunding it but would honestly rather have a working product. Looking at the video again I feel like this does (almost) nothing unless you make your animations super sharp and jerky.
Been working with it more and it does seem like it is confined to a very small range, the multipliers don't do much multiplying, or they are clamped. It is hard to tell with the lack of documentation. What are the upper bounds?
This has potential but as it is it is pretty weak.
So close and yet so far. I've messed with all of the values in the Custom script and it is impossible to tell if they even do anything. Loading, undoing, loading it with a different value. Same result. It indicates that the custom dialog box isn't taking my values, is so restricted that it doesn't matter, or is actually just faking it with presets.
The custom dialog does load the presets, but sadly, the presets are clamped pretty hard. It reminds me of the scene in the 40 Year Old Vigin, where he thinks breasts feel like a bag of sand.
As it is that's what we're getting, a bag of sand. If you're going to make it have more than a small movement you're going to have to manually go in and edit every single keyframe. You have been warned.
For this to be useful we need to know what the values are, and the simulation needs to be unclamped (or the dialog fixed, if it's bugged) so that we can put in bigger values and they are actually used.
Fingers crossed the creator makes some adjustments, this could be great.
The only settings that produce sensible results on my G8 are "average bra" and "bouncy bra". The others either clip at the extremes,
or osciallate wildly with no response to motion inputs. I am unable to reproduce the good behavior in average and bouncy bra using the custom
script, so I don't know what parameters to work with. The vendor needs to provide us with a fixed version. I'll try with G3.
Exact same behavior with G3. My motion input was an abrupt 30 degree turn about Y. Trying other axes...
