Problem with Genesis 8.1 Male
Hey all....
info first: I change my Computer and got my Library onto the new one!
Now, I got Norbert the Nerd from Mechaser in the past, and it worked fine at my Old PC, now....
https://www.daz3d.com/norbert-the-nerd-for-genesis-81-male
I wanted to load him up, and he loosm bigger, fatter, and not like Norbert the Nerd looked before!
Example here how he looked now: https://cdn.discordapp.com/attachments/1083778999337099376/1084101643072720976/norbert_broken.jpg
Could it be that there is any Essential I forgot? I updated both Starter Essentials for Female and Male Genesis 8!
Thanks for all your helps
  • FSMCDesignsFSMCDesigns Posts: 12,849
    Load the defaul 8,1 ansd see if he looks normal first. Looks like you have another morph that it on 100% on when you load the G8,1 figure. check the currently used section in parameters to see what all is loaded
  • ironmediaironmedia Posts: 18
    Ohhhhhhh nice.....
    it looked like Genesis 8.1 Male Base, has the Morph from Baku directly on... dont know why this happened,
    and now, i got Norbert like he looked before....
    Thankies so much!
  • Richard HaseltineRichard Haseltine Posts: 109,186
    2022-02-01 - Updated Baku Morph to not apply automatically on loading Genesis 8.1 Male
    You are using an old copy, redownload from your product library or through the installer you use and update/reinstall.
