Question about 2 UV swapping products for Genesis 8
Andrew_C
I see theres 2 different products for swapping UV's and textures on Genesis 8 figures
https://www.daz3d.com/genesis-8-uv-swap-male-and-female-base
https://www.daz3d.com/uv-swap-for-genesis-81
Which works better for Genesis 8.1, I seem to recall there is some difference in materials/shaders designed for 8.1?
And any other tips on UV swapping?
They don't do exactly the same thing:
So which one you need depends on what UVs the texture you want to apply uses: eg if you want to use Michael 8 texture on G8.1F, you need the first one. If you want to use Michael 8.1 texture on G8.1F, you need the second one
Moved to technical Help as it is a content question, not a Daz Studio application topic.
Thanks for the help, so I really need both, good to know
