Modeling Bevel Question
MorganRLewisMorganRLewis Posts: 233
edited April 2015 in The Commons
I've got a question for any other modelers here... when you're beveling (or filleting, or chamfering, etc.) how do you cope with tight corners? It seems that most of the time when I try to bevel a face, if there's a tight corner I wind up with bad geometry -- a lot of overlapping faces (see pictures for a before-and-after). Sometimes I can avoid it by reducing the radius, but that's not always desirable (sometimes I want a larger bevel) and sometimes it doesn't help anyway. Doesn't seem to matter what program I use either; I encounter the same problem with trueSpace (old, but I'm used to it), Hexagon, Blender...
I usually wind up fixing things by hand as best as I can, which is a time-consuming process. Does anybody have any suggestions on how to avoid the problem or to fix it more easily? (And to clarify, though I'm providing example images, I'm looking for a general approach more than ideas for the specific example.)
Post edited by MorganRLewis on
  • MattymanxMattymanx Posts: 7,000
    You have too much geometry to start with. Instead of manually trying to round the corner before sub division, just have two polys meet and bevel the edge where they meet so that when you sub divide, the software will round it off for you. The less geometry you have to play with when building the model the easier it will be to maniplulate.
  • Richard HaseltineRichard Haseltine Posts: 109,668
    modo will do a better job, I think. Admittedly that's rather expensive, and Matty is probably right - even if you do want to round that point you could do it at the same time as you bevel, which should give better results.
    Agreed. The above two have hit the nail on the head...in this case, less is more.
    To give you a better idea of what I am talking about, here is a basic model in Silo showing what I mean.
    Starting with the basic shape, I simply beveled different lines and then subdivided 2 or 3 times.
    1633 x 983 - 100K
    1633 x 983 - 81K
    1633 x 983 - 69K
    1633 x 983 - 71K
    1633 x 983 - 54K
    More showing the same model with more...
    1633 x 983 - 137K
    1633 x 983 - 101K
    1633 x 983 - 76K
    1633 x 983 - 74K
    1633 x 983 - 121K
    last few...
    1633 x 983 - 176K
    1633 x 983 - 147K
    1633 x 983 - 99K
    1633 x 983 - 59K
  • MorganRLewisMorganRLewis Posts: 233
    edited April 2015
    This wasn't in prep for subdivision, but your point about the geometry is well-taken. I cleared the area around the cusps, and didn't have the problem, and was able to smooth the point by filleting it afterward instead of before (which may, in turn, get cleaned up a little bit though it's less harmful). Since the object had multiple trouble spots and this worked for all of them, it looks like that was what I was missing all along. (Hazard of being self-taught, after all; every so often you just overlook something that's simple in retrospect.)
    Thanks for the help, guys.
    607 x 473 - 56K
    You're welcome!
