Eye set for genesis 8 product turning genitalia/breast morphs in to white.
Here's some examples on what i'm talking about.
Is anyone got a clue on what's  happening here?
          Any help is greatly appreciated.
  • I assuem you mean geoGrafts, not morphs. Select the Geometry shell created by the eye product and in the parameters pane turn off the visibility for the the aera covering the grafted elements - there should be a long list of surfaces and groups, each with a button to control visibility.
  • richardandtracyrichardandtracy Posts: 7,280
    edited March 2023
    I have had problems with applying a second geograft to a character, with the both geografts turning white, just as is happening here. Is there a limit to the number of geografts, is it an effect when they overlap or is there something else that may be causing the effect? Regards, Richard.
    Post edited by richardandtracy on
  • It worked. Thank you very much, Richard.
