How to change daz dials display
James
How to change the dials display to lists, instead of these boxes dials?
James
Get out of the Shaping tab and do your shaping through Parameters.
That is part of the "Region" coding in the figure's main asset DSF, everything listed under the main "Actor" region gets the large card, while everything listed under the sub regions (head, Face etc) gets the small card.
While it can be changed, I would not recommend doing it from within DS, as I've ended up with scrambled Regions in the past doing that.
The attached image shows the Actor region in G8Fs main asset DSF file, the highlighted line is the part you want, just change "cards_on" to "cards_off" and save the file.
That's strange, because I'm pretty sure the shapping tab was in dial list display before.
I thought I changed something accidetanly.
I look at other object, the display isn't boxes in shaping tab.
Shaping tab doesn't have display options so you couldn't have changed a setting.
Non native content (Poser, FBX etc) don't have Region coding, that content will show as list assuming the Shaping tab can find it to display them.
