SOLVED JW Pro Pose Reset for Genesis 9 Questions
xyer0xyer0 Posts: 6,399
edited February 2023 in The Commons
I've read on this forum about zeroing Genesis 9 also removing the JCM/CBS settings, and that this may be causing some of the unsightly bends in promos. I'm wondering if JW Pro Pose Reset is designed to eliminate this issue and serve as an alternative to the zero function. If you know anything, please share.
Post edited by xyer0 on
  • barbultbarbult Posts: 26,529
    You don't need a store product to avoid the Zero issues. Use Restore instead of Zero.
  • xyer0xyer0 Posts: 6,399
    Thanks, @barbult, once again.
