About smoothing iterations outfits
foxyfoxfurries
Hey every one.
I really like to use the Smoothing Iterations to shirts and make them more real on my character , But sometimes have some bug with it that the shirt goes in to my model as you see in the picture. But if I dont use the smoothing it will be like I put the shirt on my model but it doesnet looks so real.
Sometimes it fits well! But sometimes have som bugs with it.
Any one know maybe how to fix this bugs? thanks :)
Try decreasing the number of smoohing iterations under the parameters tab
The smoothing is generally ok, but in some cases it acts weird.
If so I would suggest to add a push modifier, but at a lower value than the default, e.g. 0.1-0.3
Yes, this has long confused me in that I expect the increased smoothing value to help with the fit yet I end up with more poke-through than at a lower smoothing value. I just put it down to poor programming but I do hope the issue is given some attention.
@reelyor I try this as well and still bugged sometimes , It's kind shame because its great option to use but have bugs sometimes wish this bugs will gone haha
@felis yes I also doing it but still sometimes bugged , Wanted to see if other way
@marble I really hope so! this option is just amazing wish it will work well. Most of the time it works great but even it makes sometimes bug you need to fix it and see what to do right , Well I will still use it but wish it will work perfect soon :)
