is there a way to change the names of the material fields in surface tab?
VicS
VicS
It you select the Geometry Editor amd open Tool Settings, you can rename surfaces there.
thanks felis
Be aware that if you do that it's possible it can screw up several things that you will end up needing to fix
To clarify on Frank0314's post, if you're working with pre-made content, material presets will no long work with the asset.
If you're developing your own, the same will apply with any presets generated before the change.
so best not to fool with them sounds is what I'm understanding, thanks
