Image formats - jpg, bmp, png, or tif
davesodaveso Posts: 8,277
jpg, bmp, png, or tif ? Which format do you most often save your images in, and why?
I tend to use jpg quite often when I use them for this site, smaller overall memory needed, and so forth, but I save as PNG from DS ...I have no idea why though.
  • I do everything as a png because I render everything in layers, so I get the alpha channel to comp things together in after effects.
    JPG is lossy, so it looses some finer details
  • I save renders in PNG due to the alpha channel. Never use BMP - except when holding graphics in memory in a program, it's too inefficient on space. I only convert to jpg just before publishing an image on the web, that way I don't get progressive degradation of an image due to the lossy compression compounding every time it's saved. Never use .TIF as my preferred graphics package (Paintshop Pro 5) doesn't understand the format. Regards, Richard
  • SevrinSevrin Posts: 6,314
    I usually render anything I care about to PNG, but I do postwork on 32-bit EXR canvases.  Postwork output usually goes JPGs for posting online.
  • LeanaLeana Posts: 13,543
    Like a lot of previous posters, I usually render to png, and create a jpg version of the ones I post online.
  • MelanieLMelanieL Posts: 7,874
    I render to tif which gives the transparency for layering images in postwork. But don't ask me why I use tif instead of png, it's just a habit I developed years ago!
  • Tiff is a less solid format tha  PNG - I've not seen any compliants about those produced by Daz Studio but I have had readability issues in the past when trying to open a Tiff from one application in another.
    Oh, that's interesting. I've certainly never had a problem with the ones I've saved from DS, but maybe I should make the switch to PNG to be on the safe side.
  • rrwardrrward Posts: 556
    I save raw renders as PNG files, do my post work in PSD files and publish my finished work in high-quality JPG.
    Ditto.
    And the only reason I convert is because the site to which I'm posting squawks about the image file being too big to upload, otherwise I'd just upload the png.
    png as they are uncompressed but I don't post online much at all.
  • PNG is a compressed format (I dug out the standard while hoping to write a file reader for my programs, but understanding the various compression algorithms was beyond me). PNG uses lossless compression which means it doesn't go as small as a jpg.
    Regards,
    Richard.
  • Noah LGPNoah LGP Posts: 2,617
    edited February 2023
    PNG for render and textures.
    PNG with alpha channel or multilayer PDN (Paint .NET) when I customize textures by combining several images.
    Post edited by Noah LGP on
  • csaacsaa Posts: 1,078
    It wasn't mentioned by the OP, WebP is also an alternative. "Excellent choice for both images and animated images. WebP offers much better compression than PNG or JPEG with support for higher color depths, animated frames, transparency etc. ..." (source - https://developer.mozilla.org/en-US/docs/Web/Media/Formats/Image_types
  • davesodaveso Posts: 8,277
    thats an interesting one. I've seen it a bit on the web and have saved images from web pages in that format, but I've found it is not accepted everywhere. A lot of sites will only allow jpg.
  • jjoynerjjoyner Posts: 855
    One of things that I discovered a couple of years ago when WebP starting showing up as the default file type of some of the newer products is that the forum don't accept WebP as an upoload file type.   :(   I download the product image when I dowload the content zips and I now change the download file type of WebP images to JPG.
    Regards,
    Richard.
    Thanks, that's what I meant. Similar to text compression, more or less.
  • McGyverMcGyver Posts: 7,103
    PNG if it's something I care about or I need layers, JPEG if it's not important or I need to keep the file size down on... so mostly JPEG.
    I used to get that on Macs sometimes, usually for really old clip art files, I just assumed it was something like a version or platform issue...
  • can anyone explain why do i got image formats in photo references file?
    What do you mean?
  • DripDrip Posts: 1,269
    It does give way smaller images, it just still has some drawbacks in that it still isn't carried by every browser (most gladly do now, but not everybody updates their software), some non-updated OS-es may have trouble with it as well, and finally, there is still some image editing software that doesn't support it, which means you'd treat it as a final format, not meant for further editing.
