Lali's Bodystocking for female 8.1 doesnn't work anymore
Hi,
may be someone can help me with it:
I can load whatever wardrobe I linke to load on my Genesis female 8.1. But whenever I wan't to load the Lali's Bodystoking, I the programm asks me If I want to save changes to the current scene. If yes I can save it and nothing happens if no the figue disappears and he can't find lali's bodystocking.duf. Can anyone help, please.
  • Matt_CastleMatt_Castle Posts: 3,036
    Have you tried reinstalling the product package?
  • That looks as if it may be installed through Daz Studio itself, assuming DS has been online since you purchased. Is that correct or is it meant to have been installed through one of the external applications?
  • Installed it via installation manager and then deleted it and installed it again, but still doesn't work. :I
  • If it is installed through DS you will need to uninstall it there (right-click on the product icon) before Install Manager files can be used.
  • Shadow thief clothing is the same problem. I'm just testing everything.
  • dominik411dominik411 Posts: 8
    edited February 2023
    Thanks, I'll first try that!
    And... If you do use DIM (or even DAZ Central) to install your content, do not log in to DAZ Studio, that is only needed when one makes an concious decision to use DAZ Connect inside DAZ Studio as ones primary means of installing content.
    Post edited by PerttiA on
  • PetraPetra Posts: 1,157
    Works fine for me :)
  • Deinstalled and installed it via DAZ studio and both work fine now! Thanks for you help!
