Crashing on Load (sometimes!) in Daz 4.21 (help?)
So, my adventures in Daz 4.21 continue.
A lot of the crashes seem to happen during loading of figures, especially previously-saved characters and characters (but not props) selected from Scene Subset. However, I will sometimes encounter the same errors even with something as basic as a G8 figure.
All of my drivers are up-to-date, as this is a new hard drive and a fresh Windows installation, as well as a fresh 4.21 installation. GPU, MB, etc all up to date with the latest drivers.
Some of the many error codes:
DAZStudio.exe caused ACCESS_VIOLATION in module "G:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\QtCore4.dll" at 0033:0000000054822950, QBasicAtomicInt::ref()
DAZStudio.exe caused ACCESS_VIOLATION in module "G:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\QtCore4.dll" at 0033:0000000054876300, qHash()+32 byte(s)
DAZStudio.exe caused ACCESS_VIOLATION in module "G:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\plugins\aniMate2.dll" at 0033:000000001C9555D1
Run a test on your memory; an Access Violation is a type of Exception caused when an application Reads, Writes, or Executes an invalid Memory Address.
Testing RAM today. One bad stick, two good ones, one left to test. Up next is testing the good sticks as a pair. I feel like I've somehow turned this into a Winter Olympics sport. Coming up next, the pairs competition!
Lol, at least you track down a bad stick of Ram and that is enough to cause problems.
Two dead sticks. Fotunately, they're from the same pair, so hopefully I can send them back under warranty. The remaining pair passed MemTest86 alone and together.
Will probably have to reseat the CPU again as it is running about 5 degrees hotter than normal.
Well, glad you still got two sticks.
