Dragovinian figure alters all 8.1 g8m figures
Abstract Soul
The newly released Dragovinian figure alters all G8.1 figures that I load, I read somewhere that the data file as might be set at 1, how can I change it back permanently to 0?
will this affect the Dragovinian figure when used? thanks
First, please report this - after checking there isn't already an update. You should be able to fix the issue by loading Genesis 8.1 male dev load, Edit>Figure>Zero>Zero Figure Shape, Edit>Figure>Memorise>Memorise Figure Shape, File>Save As>Suuport Assets>Save Modified Assets.
Just bought this and I have the same issue. The product needs a fix for this.
Thank you Richard,
Where do I report? do I open a ticket?
Yes
The update should be available now
Thank you
I am not able to see either the Genesis 8.1 male dev or the Dragovinian update. Where would I find either of these?
If you use DIM it should show up automatically - see attached image.
If you do things manually it is listed in the update notes: http://docs.daz3d.com/doku.php/public/read_me/index/88671/start
Thank you Joe
