February 2023 - DAZ 3D New User Challenge - Lighting and Light Effects
2»
  • DAZ_ann0314 said:
    marqueA2 said:
    Beginner challenge... Hi. First time poster! I have been intersted in Daz/3D modelling for awhile now, but have only this last month been actually learning the Daz Studio software. I have experience in studio photography, so a lot of the concepts are familiar to me, it's just needing to learn my tools. Here I was trying to learn about luminence levels balanced agaist camera settings, clearly not normal lighting, I wanted the drama. :) I can see I have a lot of work to do on it, as the highlights are blown out, and the shadows are pixelated. Constructive feedback appreciated!
    Yoga Pose Lighting Experiment 1
    Welcome to the challenge! So happy to have you here smiley
    On the pose, you did an excellent job (thats not an easy pose). I also agree on the light/shadow comments you mentioned. I would lower the light down some or change the shade a smidge which can make a difference sometimes and to help with the shadow, possible consider adding a soft fill light (generally when the shadows pixelates its just a tinge too dark) If you want to make it less destracting you could try like a light pink/soft fill that goes with the main color you chose. Or you could just go for very soft/low white/grey light as well and that should resolve the shadow issue. You could also try adjusting things a bit (or playing a bit) with exposure in the Render Tab as well. Very well done on your first challenge entry! Feel free to rework and repost and experiment. We hope you enjoy the challenge! heart
    Thank you for the awesome feedback! I'll incorporate your tips and rework my render!
  • aprilshowers2065aprilshowers2065 Posts: 795
    edited February 2023
    Summon the Light
    Intermediate Challenge
    Trying something a little abstract. I tried two slightly different lighting sets for the crystals; would like to hear which you think looks better, along with any other feedback laugh
    1667 x 2000 - 6M
    1667 x 2000 - 7M
    Post edited by aprilshowers2065 on
  • HLEET_3DHLEET_3D Posts: 172
    Title : Fairy bathing
    Intermediate challenge
    Programs : DAZ Studio + Nik Collection
    2160 x 2160 - 4M
    Post edited by HLEET_3D on
  • Cat SassouCat Sassou Posts: 9
    Title: Anae
    Intermdiate chellenge
    Used DAZ IRay and GIMP for minor post work
    1358 x 1920 - 1M
    Post edited by Cat Sassou on
  • LinwellyLinwelly Posts: 6,058
    aprilshowers2065 said:
    Summon the Light
    crystals are always a challenge, the question seems to be do you want to show how they reflect the light with caustics of light passing through and facettes reflecting the light or do you want them to glow with magic light themselves, from my personal experience I would say both is not possible to show in one object. the closes thing you might come to that is adding a point light, a spot lights or an emissive surface at the base of the crystals, trying to make them glow themselves with an emissive surface often takes away from their crystalline nature.
    So personally I like the second version better but that really is a question of taste
    lovely light settings and nice use of that gobo light, you might want to add some greenery (like a palm tree) to add to the effect  tat the shadows are cast from the plants
    Cat Sassou said:
    Title: Anae
    good work on a soft light setting, though at some places it feels a bit greyed out and  the rather dark shadow on the exe looks to hard for me.
    question, did you use bloom to achieve the effect? If yes I would suggest to set the bloom filter threshold a good deal higher (I often use abotu 9000) this might require a stronger light source to make the cut. This sounds contradictionary to what I said before but it works better to adjust the too much of light in tone mapping settings then then (e.g.set f/stop to 16)
    you might try as well to add a very low light (emissive plane) from her front to soften up the dark shadown on her eye
  • sueyasueya Posts: 842
    Version 3 of  Wizard casting a spell . I added shadows back to the pink light, but I am wondering if that is making the magic helix a bit duller.
  • EZ3DTVEZ3DTV Posts: 1,494
    Image title, “Roses in the Sun”.
    Created for the February 2023 Lighting and Light Effects Contest
    Intermediate level
    A bit about this image,
    This is a VDB atmosphere and a spotlight shines through an iron grate in the window.
    The only post effect I use is resizing the image.
    Because of the nature of backlighting, the roses were cast into silhouette and were too dark for their detail to be seen.
    For this reason, I added an emissive effect to the roses, their leaves, stems and also the vase on the table received emissive effects.
    I added the base images to both emissive and luminosity channels and adjusted the luminosity parameter to desirable levels.
    I tried to illuminate the roses from the front with various lights ghost, spot... and it subtracted from the atmospheric effect of the VDB.
    So, I opted to go with the self-emissive light effect instead.
    4000 x 2250 - 5M
    Post edited by EZ3DTV on
    did you add soem colour to the ambient channel for the spiral? I think there s space to crank that up some more
    Intermediate level
    interesting idea and nice effects!
    just an info for you, I cought covid so my responses might come a bit late, sorry about that
    Get well soon.
  • sueya said:
    Version 3 of  Wizard casting a spell . I added shadows back to the pink light, but I am wowonder if that makmagic helix a bit duller.
    Have you ever tried Bloom? Bloom will generate the sparks in a blurry effect if you want to try settings at.001 and work up. I think you like the effect creates
    she's working in 3Delight, so no bloom,
    thanks for the recovery wishes!
  • Ok, I didn't know that.
  • axionescyllasaxionescyllas Posts: 245
    Hi,
    Title: "The Green Cube".
    Created for the lighting and light effect competition of February 2023
    Daz Studio for all exept conversion to jpg on photoshop. (no post-work)
    Beginners Challenge
    I am French, I still familiarize myself with all the technical terms around the rendering and other parameter relating to Daz
    For the level, I'm not sure, I have been playing with Daz for a year. But this year, I wanted to learn and be effective. I discovered these learning competitions last week ...
    Nao is on his knees at her office to look at the light in this magnificent green cube, she looks at you and says: "Come see!", Or maybe: "Look!"
    I created a 4 wall room a ceiling a ceiling so that the light in the room comes from outside and the lamp behind it. The projected shadows are that of the window and some branches of a tree lit from the exterior with a sphere whose surface parameters I have changed to make it a light source. I used the same technique for the lamp with a warmer light.
    For the composition, it is improvisation to try to respect what I read on the challenge. But I wonder if I was not mistaken with 2022: p
    1000 x 1000 - 1M
    Post edited by axionescyllas on
    Thanks @Linwelly. After toying around a bit, I decided to go with the 2nd version, but used a canvas to add a bit of a halo to the crystals
    1667 x 2000 - 4M
    Stay well and lots of healing energy your way Linwellyheart
    This is my final version I have increased the ambiance and changed the colour of the sparkles to orange.
  • Aki3dAki3d Posts: 196
    title: caustic fantasy
    program: DS
    intermediate challenge
    My 2. picture for the challenge, also about caustics but very different than my first one.
  • apprenticeapprentice Posts: 66
    Title: The Beauty of the Highlands
    Level: Beginner - Second Entry
    Major Items:
    2560 x 1440 - 2M
    Post edited by apprentice on
    program: DS
    Fantastic caustics and DOF there!
    Major Items:
    great choice on the natural light settings there
    This challenge is now closed, thanks for participating, March will be up in a bit
    Showcase Participants for Beginner Challenge Lighting
    marqueA2 Yoga pose
    End of the watch by psema4
    The green Cube by axionescyllas
    Showcases participants for the intermediate challenge  Light Effects
    RexRed Roses in the Sun
    Cat Sassou with Anae
    and New Users Welcome
    MattD80 with Light in the House
    Thanks a lot for pariticpating everybody, well done!
    Thank you for choosing my piece in the intermediate contest! I am flattered to win among so many other great entries! It was fun being a part of this event and all the best to everyone involved. Sincerely, RexRed. heart
  • Congrats to the winners laugh Great pieces
  • Gratulations to the winners. Keep going.
