textures flat in iray
lumiasart
hey everyone,
today I opened and older scene and found that the textures look flat in iray. I tried rendering it and it does look better. Could it be a viewport issue?
thanks!
Looks like you've turned on the denoiser and just aren't used to how it looks early in a render.
The Iray Drawstyle is not identical to the render, it may also be that one of the differences accounts for what you are seeing.
The Denoiser is In the Render Settings tab, under Filtering. Post Denoiser is what it says.
that was it! thank you so much! <3
