Installing of Daz Studio stopped
Hello All,
I installed Daz Central, but Daz Studio installing stopped at 89%, this is the situation for neary 1 week now.
Can someone help me how to solve it or what can be the issue?
  • Try using Install Manager - it should pick up the settings from Daz central but seems better able to cope with recovering partial instalaltions (in this case, I suspect the application and perhaps some cotnent are isntalled and other content that is part of the basic Daz Studio product set are the problem).
  • joannajoanna Posts: 2,245
    imre.molnar1990 said:
    Hello All,
    What helps me in the similar situations is just closing Daz Central, reopening it, and installing again: it usually picks up where it left off. Last time when I was installing the whole Studio, it often took multiple restarts of the DC for the installation to finally pick up.
  • imre.molnar1990, uninstall everything and use Install Manager.
    Daz install Manager (DIM) is much better, it will handle all the things you got from Daz.
    Also look for how to install DIM, good luck!
