DaveyAbbo Morphs
I've purchaced a number of DaveyAbbo products, and seem to have the same issue with each.
When I apply his morphs to my characters the level of edge displacement seen in the promos does not seem to translate to my renders.
The textures I get seem smoothed over and less defined. I have posted some examples.
I'm not sure what I'm doing wrong here....
JD
  • FSMCDesignsFSMCDesigns Posts: 12,844
    What level of subdivision are you using since their products rely on very high levels most of the time.
    To be honest... I have not converted to subdivision surfaces...
    I wish there was a pdf file included with these , showing best practices , as I'm just loading the characters with the default settings...
    Even a note in the menu would be nice...
    JD
    Jist try it and see if there is a difference. Click on the figure and then in parameters, under general there is a mesh resolution section. If the setting is 2, then turn it up a notch and see how it looks. be careful turning it up to much as that will really impact your system (normal systems can't usually handle more than 4)
    Thanks!
    I was looking at the texture compression thinking it was something to do with that, but this seems more likely.
    JD
  • Yes!  That was the answer!
    It now looks much better!
    JD
    yes
