IRAY Decals with weird bright seams
Hello,
I have some strange issues with iray decals that happen once I use spotlights (independend of mode) and I zoom out so that the decal is very small w.r.t. to the image size. In this case, they get a bit of wrong rending of the transparency making them bright seams at the place where the transparency is not 100% but a value in between. Am I the only seeing that? It goes away once i move the camera closer.
Christian
The same issue was with 4.20 .. I upgraded to 4.21 today because I hoped it would be fixed.. but what is broken and how is the alternative?
might be related to this: https://www.daz3d.com/forums/discussion/612441/iray-decals-will-only-accept-0-or-100-opacity-otherwise-interfere-with-shadows#latest
might be a separate issue unrelated.
you could consider submitting bug report here: https://helpdaz.zendesk.com/hc/en-us
The tip with the geoshell worked! Thanks!
